The options will be greyed out until you OVERRIDE the font you want to change. Right-click on the font you want to override (body, for example), and a pop-up will be displayed asking you if you want to override it. Select it, and then you can set a font for the body. Repeat for heading if you also want to change it.
How kind of you to tell me the hidden secrets. Pretty complicated. On their vids they always say it’s easy and self-explanitory. Again, I cry out for a newbie’s step by step manual!! Thanks everyone for helping out. Let’s see what I can do…
Hooray! Yes, I’m in. Why are we using Google fonts? I miss the Apple fonts.
You can also use your own fonts; they don’t have to be Google. You would add them as resources in your project and then drag them into the theme studio, where you set up the fonts. The fonts you provide need to be in WOFF2 format.
