UI Settings Not Being Saved
I have now upgraded to the Rapidweaver Elements Version 3.0.13 (24543) and have now identified another anomaly related to the saving of the UI configuration.
In the following screenshot I have created a display profile named "Standard’.
You will note that the Resources panel sits between the ‘Pages’ and the ‘Components’ panels.
However even after saving the project file, closing Elements and reopening the project file the configuration settings are not saved and the UI is altered as below.
Why are the UI settings not being saved?
Problem solved! - saving the project file does NOT automatically save the workspace settings - the workspace settings need to be independently saved within the Workspace configurator
Exactly, I’m glad you figured it out :grin:
