UI/Workflow Question
I’m really loving working with Elements - thanks for all the hard work building this amazing app!
Question: When I am working on tweaking things for responsive design - switching between screen sizes using the buttons near the top right of my workspace - is there a way to configure the Component Inspector so that I am looking at the same setting for each screen size? For example, I want to adjust Spacing settings for each screen size. I start with Mobile (mobile first!). I have the Spacing settings expanded in the Component Inspector. When I jump from Mobile to SM to MD to LG, I want the Inspector to show me Spacing settings for every screen size. As it is now, I often have to explicitly open the Spacing settings for every screen size because the Inspector seems to remember what I was looking at the last time I was there. Workflow would be improved if I could see the same setting each time I switched screen sizes.
Thanks in advance.
I too would like the inspector to keep on the same setting, even when I switch to another component. Or maybe an option to have it doing that.
I have been dreaming about this feature since almost day one with Elements as it is painful to go through a lot of elements trying to check one set of settings.
It’s worth adding it to the wishlist
I also would dream about such an option. The current behaviuor sometimes drives me crazy.
