Unable to connect Element with AI Claude
Bonjour, I followed the instructions to connect AI Claude via MCP port with Element, the Claude application seems to be configured correctly but in Element I still do not have access to Claude.
I have a free account with Claude, is that the problem?
Help me
The key words in your query are “in Element[s]”. MCP works outside of Elements. You type in your usual Claude chat window and it does things by communicating with Elements.
With Elements running, type the following prompt in your Claude chat:
Can you see Elements MCP?
If you get a negative answer, then you probably haven’t configured Claude correctly.
Sometimes you’ll need to close the Claude application and restart it if you, for example, started Elements after Claude after rebooting.
