Unable to connect via SFTP
Hi, I have the same problem with SFTP. None of my projects will connect to the sftp server. I last published my files to the server at the start of the year. And when I tried last week I realised there was a problem connecting to the server. I’m using Rapidweaver 7 though, not Elements
Hope someone can help
Joe
Hi @JoeMolloyShaman
RapidWeaver 7 stopped being developed many years ago. Your web host might have updated something on the server side that renders RapidWeaver 7 incompatible with SFTP publishing. Your best bet would be to upgrade to either RapidWeaver Classic (if you want to be able to import your old project file and keep your existing site and settings exactly the same), or to RapidWeaver Elements (if you want to rebuild your site using a newer and more modern framework).
Your web host should be able to give you more insight into why your SFTP connection is failing from RapidWeaver 7 though, if you prefer to try and stay on that outdated version of the app.
