Understanding the AI MCP connection
So I’ve got chatgpt connected to elements via MCP, but I don’t really understand the process. It doesn’t look like there’s any specific command set for this approach within elements, correct? With MCP, I can’t grab an image and say, “Make me variations on this?”
Instead, it’s driven through the chatgpt end of things? While within ChatGPT, “Use elements to…” kind of prompts? Do I have this right? (If so it seems a step removed to make it a convenient process, but I may be missing the big picture.)
It’s going to depend upon the LLM. I use Claude, so I can’t tell you how ChatGPT handles requests.
But yes, you can literally start with Elements open in a blank, new Project, go over to the chat window in your AI and write: “I need you to create a Web site in Elements with the following pages: home, blog, contact. Each page should have a consistent menu header, banner, content area, and footer. You can ask me for which things to put in the footer. When you create the blog, populate it with a couple of sample articles. Go.”
Depending upon your AI and your account, it might take awhile, but after awhile you should have a three-page site. Now describe what you want changed.
Hi all
I’m new to using AI in Elements myself, so I may be teaching people how to suck eggs, but here is my experience as a novice at this stage.
I experimented with ChatGPT and Elements last night
I set it up through both MCP and with an API key.
I just followed the instructions in this video, and I was up and running in 5 minutes.
API Method:
The API Key method is definitely the easiest to use as it can all be done from within Elements.
I asked it to create sections on a web page based on images of layouts I had, and it did it very well. I just typed, “Using the core components, create content in the container called ‘Services Container’ using the attached image to show you how I want it to look”.
It did a great job creating what I wanted, and then I either asked it to make small changes or adjusted them myself (padding, margins, background colours, etc.).
It also didn’t get it exactly how I wanted on mobile view, so I asked it to change it.
For example, on desktop view, I had a row of 4x SVG icons with header text underneath them and on tablet view it moved them to a block of 2 rows of 2 columns (great) but on mobile view it had 1 column of 4 rows and it didn’t look great so I just asked it to change it to 2 columns and 2 rows for that view and it just did it. It saved me a lot of time.
The downside to the API key method is that you have to buy credits, and depending on what you ask it to do, it can use them quickly. I quickly realised that GPT-6 Luna is much cheaper than GPT-6 Astra so you might want to experiment with the results from using Luna first.
Personally, I am definitely going to use this feature a lot to significantly speed up my workflow and I will just budget for API credits for each project. I estimate I could probably build twice as many websites in a month using AI with Elements.
My advice for anyone who hasn’t tried it yet is to add $10 worth of credits and ask it to build a section for you on a web page. Try using GPT-6 Luna first, as that uses a lot fewer credits up.
MCP Method:
I have only just started experimenting with this, but it already feels less intuitive.
I think it could work well if you worked on two screens and had ChatGPT desktop open on one and Elements open on the other.
I’ll try to stick with this method because, as I understand it, you don’t need to buy anything else.
I have a basic £20 a month subscription to ChatGPT as I have been using it for image creation, content writing, formatting css code, etc, over the last few months and it has made a big difference to my workflow.
Someone with more knowledge and experience of AI, MCPs and APIs than I do (which isn’t difficult :joy:) may be able to give a better explanation, but just from putting my feet in the water a little over the last 24 hours, I am blown away, and it’s going to change my workflow for the better significantly. It is going to allow me to design website layouts in graphic form and then leave the construction of them to AI. Provided it’s all done within the Elements framework, I will be able to make changes when necessary. If I get stuck, I can just ask ChatGPT to do something for me.
Over time, it will allow me to build up a good selection of components to reuse on other websites, which will speed things up for me even further.
I hope someone finds this useful, and sorry for waffling on.
All that’s really different from a basic UX point of view is that you’re using a chat window outside Elements instead of inside Elements. On my big display I simply make the Claude window tall and narrow just to the right of my Elements window (I also close the right panel most of the time in the Elements window).
There is a bit of a difference in terms of “memory.” With API, Claude will create Markdown documents in your Project to keep track of requests, styles, to-dos, etc. With MCP, you’ll want to manually rig that. One difference is that inside Elements, editing a Markdown file that the AI uses is a no-no; outside, I’ve given Claude a skill that allows us to both use a project planning file, and we both annotate and mark it up following some basic rules. So I post things into that file when I think of them, then the next time I fire up Claude it looks at that file to see if there are things it hasn’t done yet. Some of my Claude conversations now are so long that we’ve not only had to compress them, but organize them into a JSON file.
The reason I don’t use API is that it’s more expensive to do the same thing. So, sure, it’s easier to hook up and start using, but you’ll pay for that…
Hi @thominator
Yes, I soon realised it could get expensive to use the integrated AI in Elements via an API.
In my existing workflow, I pay around £50 per website for a license to use a particular WordPress theme that I know like the back of my hand, so in my head, I was thinking I could use that money to pay for the credits required to build websites using AI with Elements and speed up the building process at the same time.
What I am actually trialling now is using another Apple device, like my iPad Pro, as a separate smaller screen extension to my main wide monitor, and I have ChatGPT showing on that. This allows me to put ChatGPT to work and watch the changes come in on Elements on my main monitor. So far, it’s working well and removes the API cost issue.
I’m new to AI integration into apps so I am still finding my feet with it all.
Wow, appreciating the back and forth here and learning a lot. Thank you both.
24 hours later, I am fully in on the MCP connection method. It just means you have ChatGPT (or whatever AI agent you are using) in one window and Elements in another. By doing that, you don’t incur any further costs. I also think it’s better this way now, since you have more space to type your commands in a larger ChatGPT window than in the Elements’ sidebar. Whatever works for the user, though.
I have found it easier if I extend my screen with my iPad Pro or my Apple TV as that frees up the full width of my monitor to watch ChatGPT go to work on a website in Elements.
So far, I have asked to modify various things, such as moving the small dropdown sub menu triangle in mobile view to somewhere closer to the link (rather than all the way over on the right, which didn’t look right to me). I also spent 15mins trying to figure out where to change the top and bottom padding of only the sub menu links, then gave up and told ChatGPT to do it (which it did in 5mins). I watched it open the relevant files and make the changes. Very impressive.
I know I am going to be using it more and more to do stuff.
Maybe add keyword rich titles and meta descriptions to pages to ensure they are optimised for SEO purposes.
It really is a game changer so give it a try if you haven’t already.
Happy that worked for you @fusionxs . It is an interesting way to work, and watching the ongoing work the AI is doing in the Elements window can, at times, help with understanding some of the nuances of Elements.
FWIW, adding titles, descriptions, share stuff is one of the things where an AI really earns its money. It can make short work of even my thousand+ page sites, which would take an enormous amount of time to do by hand.
With chat outside of Elements, I’d encourage you to do one more thing, and that’s build a to-do and history file. In my folder for a site, I keep a Markdown to-do list. I’ve told my AI to look at that list and pick off one item at a time. I’ve also instructed it to keep a Markdown history file of changes it makes to a site. One problem you’ll eventually have if you use an AI too much is that it starts to lose history states (memory). You’ll even see the chat from time to time say “compacting history.” That’s fine. However, eventually the AI will only have a general sense of what it did. If you force it to keep a detailed file on your computer, you can always point it at that to refresh its memory.
I’ve made a small upgrade to my setup and bought a lightweight portable display from Amazon for £48 that connects to my Mac Mini via USB-C, so I can have ChatGPT available whenever I want on a small screen beside my main screen. It feels very natural to have it running on the left and Elements in full-screen mode on my main 34” display. It’s also a great size to view my iPhone when I am using iPhone mirroring. I didn’t have enough desk space for another 34” display, so it fits perfectly on an old iPad stand I had.
Great looking setup you’ve got there. I’d also like to get a second display and turn it vertical for ChatGPT/Claude specifically.
There is something about giving AI its own little screen that feels very natural.
Especially when you have it at 90 degrees.
I also have a 32" Full HD TV to the right, with an Apple TV connected to it.
I did try using AirPlay to extend my display, but it didn’t feel smooth enough, and I usually have something on in the background most of the time.
An iPad will do a similar job but I think a wired connection gives you the best experience.
I will also take the small display with my laptop when working out of the office, as its just one USB-C cable for power + display and the extra screen will be very useful.
This was the one I purchased, but there are lots on Amazon.
Great to see you guys digging into the AI side of things, I’m itching to try this myself, but I can’t help thinking the optimal way to use this, is with AI embedded within elements itself - however, as you have all pointed out, with the current setup, that means we need to pay for API usage.
@dan - is there as reason why we not able to ‘sign in with ChatGPT / Codex’ and use our existing plan, rather than using API credits..? Seems most people here are on a monthly plan, so would save us paying for API usage on top of that…
Unfortunately, it’s not possible to do that both of their terms of service prohibit it and don’t allow it as far as we’re aware. It’s why this isn’t a thing in any apps :frowning:
For the best bang-for-buck, use the MCP :blush:
Hey @thominator
Just curious if you’ve used ChatGPT as well as Claude, and how they compare.
I tried a local LLM model (Baidu Ernie 5.5 Flash), and whilst stand alone it can design pretty good looking sights, it was quite useless at gettings its head around designing within elements.
As you seem to be running local LLMs too, just curious if you have any tips on how to start them off on the right footing! Thx.
You have to remember that LLMs are living organisms. What doesn’t work today may work tomorrow.
That’s a primary reason to use ChatGPT or Claude, as they seem to improve the more you (and others) use them for a task. What Claude can do today via MCP is more than it was when the link first was enabled.
The problem with the local LLMs is that they’re “open.” They’re tuned to the mean, basically. So while they understand the MCP connection, they aren’t improving the usage patterns (and more).
Moreover, on the local models, you can end up parameter/bit bound. I don’t have Baidu 5.5, but 4.5 was a general purpose model, not specifically trained towards something. I tend to use programming tuned local models.
Finally, your words “designing with Elements” needs some more flesh on the bones. Initial design, tweaking via the Inspector, re-arranging, and all the other things you do in Elements are different things, and different models do each of them at different levels. A general model will see the Components that Elements surfaces, hopefully read the docs for them, and then use those like Legos for what it was taught is good Web design (which I’m pretty sure I won’t agree with ;~). I’ve found most of the better local LLMs work fine at that.
It’s when you have a site and you start asking to nudge things or change breakpointing, or re-arrange, or use things that are deeper in an Inspector setting that things start to break with the local LLMs. Even Claude, which is the best of breed right now with Elements (ChatGPT isn’t far behind) trips a lot. For instance, I was trying to figure out why I couldn’t get rid of some space. The models will look to Spacing first and foremost. Even Claude missed that there was a MT-20 instruction in an Advanced setting. This is where humans start to work better, as long as we have a good underlying knowledge of the system. I’ve found the same to be true for coding apps, too: most of the time the best models work fine, but for some problems I have to scan the code to find the thing they’re missing.
Thought I’d share what’s changed the most for us, in case it’s useful to anyone here.
The biggest jump came when we had Claude pull everything the MCP exposes about the Components and build a local database from it: what each Component is, its settings, and where those settings live. After that, the AI stopped guessing. It already knew how Elements is put together before touching a project. It also stopped spending usage relearning the Components every session, which adds up quickly, especially for anyone paying for API credits. Every so often, we ask Claude to audit the Elements MCP and update the database.
The second change followed from the first. Since the AI no longer needs Elements open to learn the Components, we keep Elements closed while it works. We open a site’s project once so Claude can connect to it, and from there it works on its own. That means it can run several sites at the same time instead of us watching one window. When a build is ready, Claude publishes it to a test server, and we review it there.
The work also isn’t tied to one Mac anymore. We can have more than one computer working at once and check in remotely, even from an iPhone. Each website gets its own session inside one Claude Project, and Claude keeps its own notes as it works. Nothing gets lost between sessions, so work can stop and pick up again without starting over.
The AI takes the repetitive work, and we spend our time on the parts that need a person: design decisions, content, and checking the results.
So glad to have opened this topic and learning so much from the folks with more experience. I was able to get it to work first hand with a tricky video header that I couldn’t get to resize. With a natural language query or two it managed to refit it with some html code inserted into the advanced functions. More to try/come. Thanks again to everyone who has weighed in!
