Upgrade LANDER project for Elements
Hi guys, here another Classic Icon Design,
Lander RWclassic Layout vs Elements layout
… If you are thinking of switching to Element Lander Project is ready!
LANDER design for Elements.
This project uses Elements’ layout tools to create a clean, consistent design that works smoothly on all devices
lander_project_001
lander_project_008
3x Navigation:
:right_arrow: Regular Menu :right_arrow: Regular & Vertical Menu :right_arrow: Only Vertical menu
lander_project_007
Options beyond Elements and Custom Components
Back to top button, Scroll Bar, Banner Parallax, Fade-In BODY and also the Breadcrumbs.
Take a look
lander_project_components
Project pages:
Home, Pages, About, Contact, Helps, Gallery and ‘ ‘Starter Page’, your starting point to launch your website!
Check out the live preview to see it in action!
Here a coupon 20%Off for community members
landerreborn68320
Thanks!
Congrats on the launch of another Classic!
Yep - had that one too :slight_smile: very nice :blush:
Upgrade V1.0.1
Project for Elements 2 with new page ‘Sample 2’
Components demo page, Content Slide, Table (with extra css animations) , List Tabs and Markdown
lander_elements_2
If you’re using Lander in Classic and want to switch to Elements, you can now :slight_smile:
_________________________________________________________
Available in the Marketplace
The project is currently on promo! :smiling_face_with_sunglasses:
This is they first Elements theme I purchased. Time to build my website again. Thanks.
LANDER looks great, Michelangelo!
Do you think you will ever be migrating the PLAN theme over to elements?
I’m thinking it would be easier for my transition to stick with the same theme.
Chris Thank you very much. I have some layouts in progress, Plan included :slight_smile:
But I’ve changed my plans to develop with Elements for now. The policy would be to support the transition from Classic, at least as long as the ecosystem is supported by RMS.
We’ll see :sunglasses:
Awesome job like always Michelangelo! :star_struck:
Thanks a lot Hans :folded_hands:
