Upgrade RW8 or not?
I’ve been a long time RW user (started on RW3). I stuck on RW8.9.4 a while back as it worked well for me and as I was building less new websites it is fine for the simple occasional updates.
I also stuck with my Mac OS 12.7.6 to ensure that RW would continue to work OK.
I now find my Mac OS could do with updating as this has prevented other software (for eg Safari, Chrome) from being updated.
So would update of my Mac OS to Ventura 13.7.8 cause issues with RW8.9.4? Or should I upgrade to RW Classic… but would this have issues with my old RW8 projects (lots of old stacks!)?
Thanks for any help / advice
Steve
Hi @Steve_F
We’d definitely recommend updating. :slightly_smiling_face:
If you are wanting to update to macOS Ventura 13.7.8, the newest RapidWeaver Classic release should work fine per our forum announcement here.
The only plugin that wasn’t working specifically on RapidWeaver Classic was RapidCart. If you are not using that plugin I believe your older stacks would work fine. You can always download a demo version of the app first to test though.
Let us know how you get on, and thanks for your interest in upgrading, lots more great updates coming soon. :slightly_smiling_face:
I’ve also just realised that RW Classic is an annual subscription… will it stop working if I don’t renew after 1 year?
You can keep using Classic for as long as you like, even if you cancel or stop your subscription :smiley:
Renewing is always optional. If you stop, the version you have keeps working with all its features. If a later update catches your eye, or you’d like to support our work, you can renew then.
We have a whole Q&A on our pricing here if that helps reassure you.
Cheers!
