I would be grateful for any comments on this problem that has just arisen.
I was tweaking a few things on a page. I was adjusting the size of an image from 100% to 70%. The image is on the server and I was changing the % in the tag. Suddenly my page doubled in size and the picture which should have been 30% smaller was much much bigger affecting the size of the page.
I have no idea what happened. I tried logging out and back in but it seems to be stuck in that format.
Never had this happen before? I donβt think I hit any odd buttons. When I preview the page it is distorted.
Any ideas or solutions? You can look at the problem at http://frankhanna.com/york/ which is a test folder I have set up to illustrate. The picture in question is the second from the bottom.
Frank
