I am adding a new web page to my website and this new page is using an HTML component.
When I click on the Inspector there is code there already that I remove. I paste the new HTML code in and immediately I get an error screen that can only be dismissed by closing Elements.
@irishchristo I wonder if you are making the same mistake I made. You need to create a new HTML for each code block that you wish to insert. Only use an existing one if you want exactly the same code.
You can name the HTML blocks in the title section:
Thank you. It is interesting as I asked Claude AI about this and got a reply saying that there is a bug in the software so I passed this on to Rapidweaver
If ou mean delete a custom component HTML then just right click. If you mean the code within block just highlight it and delte as normal. If I am creating a code. I always duplicate it before removing stuff just in case and you can go backwards.
Thanks. You’re right, right-click to delete or rename doesn’t work when Components is in its own window. It works when it’s docked. There’s a fix in next release.
