Using markdown within elements
Hi All,
Long time RW user.
One of the easiest way to learning a new program is just converting a simple working site.
I have a few of these simple sites that just use Markdown & Images
Is there a way to work with markdown within elements?
If I was using RW8 & Stacks5
I’d open a new project.
Add Stacks
Add the Stacks Markdown stack & add content.
And it could be seen in the main page
In Elements
Open a new project
Right click on “Untitled Page” Choose- New Markdown File
Fill in Title, Date, Tags & Categories – add content save.
And you see nothing, under the default page…
I have only done it this way since I did not find a Markdown in “All Components”.
And yes, both Text & Typography do work, but having to convert five years of fully configured Markdown files will be an unpleasant task.
Markdown files are currently only used with the CMS. There is no dedicated Markdown component, unfortunately.
@abcole I have some news on the Markdown front, check this out…
