Vibralogix Store Solution Praise
Wanted to throw some positive praise on Adrian over at Vibralogix. I started with one store to test it out - now I have three stores!
I was an old rapid cart pro user and had to have rapidweaver 8 around to try and make the old stores last. (Pain point)
The new Vibralogix stores are much better, easier to use, and provide a wealth of customization for your needs.
I am a musician (trumpet player) and not so technically minded… tried to write code a few times…
So I can give Vibralogix a 1000% endorsement…
Adrian was very very very helpful and helped me a lot. He even helped to set up the stores…. Went way above and beyond customer service… bought him some coffees for his efforts…
600+ items at PlayTheBlues.com
Smaller stores at TrumpetLessons.com and TrumpetStudio.com
Please consider supporting this outstanding developer….
Vibralogix and Adrian in particular are exceptional! As you mentioned, their customer service is unparalleled, and the products themselves are incredibly useful.
I will also add praise. Setting up a store is always work… and Vibralogix works when you get through. Which is awesome. You are in control, the back side stock and client end works great, and the communication with the developer is also strong.
Thanks for a great product, and strong documentation.
