I have set all the web icons of the project but it seems not to work, they are not displayed on the browser tabs.
Can you share the project (via Elements Cloud) so we can take a look?
It’s a project file that I might want to sell. So just to be safe I ask you (even though I don’t think it will happen) if I upload it to the Cloud will it somehow be accessible to other users?
We generate unique IDs for each shared file…
The ID token has 12 characters. The probability of someone guessing or finding it is incredibly small.
Total combinations = 62^12 ≈ 3.2 * 10^21 (3.2 sextillion)
A bot guessing one per second would take trillions of years to hit the correct value… so it’s probably safe!
However, you can email it over directly to me if you prefer and we can take a look ![]()
Yes I imagined it was more or less like this
Anyway, to better understand how it works, when I click on the Cloud icon a backup of the file is made at that moment, but if I make changes and click the “Save” button it continues to save the project locally. Is this correct?
Correct, it’s a copy/backup of the file at that moment!
I uploaded the project file to the Cloud.
Great! Do you want to email me the link so I can take a look?
What email address should I send it to?
I can’t send you a message here in the forum because they are disabled.
You can email it directly to me here ![]()
@Massimo I’ve taken a look at your project, and first of all, I need to say WOW
It looks flippin’ amazing, nice work man!
The favicon issue: As you’re publishing to a subfolder, the paths are wrong for the favicon resources. That’s a bug in Elements, and we’re working on a fix as we speak.
Should be fixed in the next build or two ![]()
Thank you, ok ![]()
Hey @Massimo, Good news!
This has been fixed in build 0.8.5, available now ![]()
