I can’t tell if my web icons are working or not. I think they need to populate. Does Elements size the icons or do I have to do that?
I’d need to check with @tpbradley (or do some testing), but as far as I remember, we resize those resources automagically.
You can check them by doing a local export and inspecting the files in Finder.
Hope that helps!
They appear to be working now, so I would say that Elements resizes them for their intended use.
