Website does not fill mobile screen
My website does not fill the mobile screen from left to right. What gives?
do you have a URL we can take a look at?
Yes. Monemus-cm.com
Thank you.
You’ll need to alter (on Mobile) or remove the sliding in animations - they are sliding in from the side, that’s why the extra space is seen on mobile.
If you share your project via Elements Cloud I can fix it for you.
Attempting to sign in to cloud. Elements times out and I don’t get the registration email.
