I am building a website in Elements with the North Eleven template. I have been using the Jost font and the embedded fonts. The website needs to be viewed on Apple devices which are running Apple’s Lockdown Mode which restricts the ability for the browsers such as Safari to reach and use web fonts and I believe I am not 100% sure but I think it also restricts non-system fonts from loading. Is there anyway to make the site if it doesn’t access or use the Jost font embedded, to switch to a system font specifically Helvetica or Arial. Right now I am getting a times new roman style font and it looks ghastly. Thank you.
PS I have tried embedding the fonts into the project but it makes no difference either.
For some reason it is displaying Jost as Times New Roman in lockdown mode. Is there anyway to force it to use a specific system font such as Arial or Helvetica?
Lockdown Mode blocks most web fonts, so Jost won’t load however it’s added to the project. When that happens Safari uses the next font in the list, and as there isn’t one, it drops to its default serif, which is the Times look you’re seeing.
You can add the fallback yourself:
Publish or preview the site, open it in Safari on your Mac, right-click some text and choose Inspect Element. In the Computed styles, find font-family. It’ll be a name like font-6DDB028D-…. Copy the whole name.
In Elements, go to Project Settings > Template and paste this just before the closing </head> tag, swapping in your font name:
Normal visitors still get Jost, and devices in Lockdown Mode will show Helvetica, or Arial if Helvetica isn’t there, instead of Times.
If Jost is your only font, that’s all you need. If you’re using a second font for headings, let me know and I’ll adjust the CSS so it doesn’t override that one.
Hello Ben - Thank you for your kind reply and help. Just wanted to say that you are amazing and this fixed the problem. Now the site doesn’t use the ugly TimesNewRoman and doesn’t look pants in lockdown mode. Thank you!
