just started happening (I think)
checked z = 50
check all opacities
checked background
what is the setting?
thanx ![]()
This is my largest - oldest site TrumpetStudio.com
Nuke and pave? Delete: Mike’s Top Menu
Make a new global menu?
@dan not sure what to do ![]()
(Tried changing z index to 300 - no change)
If the menu is in another component (container, grid, etc), try setting that component’s z-index higher
This is very old - do you remember recovery nodes?
I think is the name - had 300-400 errors
I deleted the existing menu that caused the errors…
I think this is the third menu…
Thanx for trying to help…
Well Got It Working With A Fresh New Menu
Does this happen to you? The first container after the menu has to be lowered 28 to see the content…
So deleted old global menu? Insert new global one drop the first container by 28? @dan
Or?
Robot say lower the first container ![]()
New menu installed - old deleted - all working
Is your menu set to be sticky or not?
I have found if I use a sticky menu that I DO NOT need to offset the container below the menu. When I set up the sticky menu, I set all of the position values to ZERO using the individual option.
Robin - my menu is fixed…
tried your settings for individual option - did not work
but thank you for taking the time to try and help
best
-mike
They would not work for fixed; the menu would have to be set to sticky. I have four sites using this approach, and they all work flawlessly. Maybe something else going on, hard to say without seeing all of the settings.
