What are the system requirements for Classic 9 and 10?
I would like to know the system requirements for Classic 9 and for Classic 10. There is different information in various places and I’m not sure what applies for 9 and what for 10.
Announcement 10 Beta:
What’s new in Classic 10.0 Beta 1
RapidWeaver Classic 10.0 requires macOS 12 or later.
In the Docs:
RapidWeaver Classic requires macOS 10.14 (Mojave) or newer and works great on the latest macOS Sonoma.
On the Classic product page:
macOS 15 Sequoia or later
Thanks in advance!
We’re jus in the process of updating the documentation for Classic. More to come on that soon.
RapidWeaver Classic 9.x runs on macOS 12 or later. However 10.x is going to require macOS 15 or later due to the new technologies we’re going to be using in the Block Editor (and other unannounced features).
So if you’re running anything earlier than macOS 15, you can continue using RapidWeaver 9.x and if you’re on macOS 15 or newer, you can safely upgrade to RapidWeaver 10 whenever you’re ready.
Hope that helps clear things up.
That’s very clear, thank you!
