Have you done some kind of upgrade automatically? All of a sudden the Resources isn’t an icon anymore and clicking on resources doesn’t work, you have to find the invisible little box above it. Quite apart from the fact that when one does finally click on it, it doesn’t show the pictures present in the resources anymore. What has happened? i rely on that feature to check and remove, images but they are just not there.
Did you already try to restart your computer and check again? Otherwise try to download a fresh copy of RapidWeaver and see if that issues still exists:
Sounds like macOS is having trouble displaying some of RapidWeaver’s screen elements.
As @RapidBase said, have you tried turning your mac off and back on again? (And yes - I do sound like Chris O’Dowd in my head when I type this - I’m sorry)
This forces macOS to reload Aqua and will most likely fix the issue.
A complete moment of panic. A restart didn’t work but a reinstall did. Calm restored. Thank you very much both of you.
Phew, glad to hear you’re back up and running!
