Where am I adding "Add Resources Folder" from?
Where am i adding “Add Resources Folder” from? The two images that i want are in the resources folder of the left sidebar (highlighted with red “>”).
Or should it be saying “Add From Resources Folder”. But if I add the two files by dragging them into the Gallery, nothing happens.
This is trial version.
What it is trying to tell you is that you need to drop in a FOLDER of images, so the five images you have in the resources need to be placed inside a folder, then drag that folder into the gallery.
You can select the five images and then right-click and choose “Folder from Selection”.
@dan @WOS
not sure if this is a bug or me, thought previously I could select photos then right click and create folder from selection, now I have to select the images then right click on Resources??
That worked for me - selected photos then right click and create folder; thank you.
But it doesn’t work a second time to create another folder for another gallery…..
you cant use the same image resources for multiple folders…. have to re-import for each folder
Yes, I just noticed this as well, seems like something got changed.
Ah yes, this is a small bug, we’ll get this fixed!
