Why am I getting a white space
I was flying by the seat of my pants when I started this project, but I think I’m catching on better. Thanks again for your help.
The double menu issue happened once before and I had to unlink from global and delete each item. I’m not sure why it showed up then and I’m not sure why it showed up in the project I uploaded to you. it, it wasn’t there in the my version and its not there now.
I also wasn’t having the issue with the iPhone view that you corrected again in this video. I did just correct the social icons so that they are centered.
No idea I showed downloading the posted project can you share again
Here it is again
elementsapp://downloadDocument/T5UqhoCLVuTy
ok two downloads of the same file have different top component order
still have issues with sizes of components and padding margin, also you menu is in the everything container and the same on another page
the px settings should have been auto
took your menu out of the containers had to add color but now works
Everything was working fine on my project, except the Books drop down menu. I tried taking the menu out of the containers, but then Elements wouldn’t let me remove the “Everything” container. I remember this happening before. I quit Elements and when I reopened the project I got this warning, as I did the other time. However, now all the errors you saw in the cloud version are back, the extra menu is above the correct menu, and the side issues are back. Is there a corrupt file?
try this
I am back on the project, but I still can’t figure out how to make the drop down menus appear on the top of the banner. I couldn’t do anything with the" “Everything” folder until I unlinked it from global. Then I deleted it.
elementsapp://downloadDocument/PFejFEyunzz9
ok a couple of areas still causing float, you probably need to check them all
still not sure why you have a menu in a menu container I took it out and it then works, messes up a couple of pages and background color, lost menu on a couple of pages,
getting there a lot more centered without padding, just a couple of things to sort, looks a cool site
Fingers crossed, but I may have fixed it! Once again I really appreciate all the help that you have given me,
