I can’t seem to get my frame to go full width of screen. I am using a 2 dimension table inside a container. The light gray info near bottom of screen doesn’t go full width. Thank you
Without a URL or more information it’s hard to say.
Thank you
It’s because the columns are inside a Container stack which has a width set to 1110 pixels. Either take the columns out of the container or increase its width to the correct size.
Got it thanks alot
