Window Sizing Presets etc
If I drag the right-hand side of the WYSIWYG Editor to make it larger or smaller, the size ( nnn x nnn) alters to the left of the size selector icons on the top right of the page. As the size increases the appropriate icon is highlighted. Alternatively, if I click a size icon to select a specific size, the page size changes but the indicated size doesn’t alter and therfore becomes inconsistent with the size icon selected and the resultant page size.
Also, maybe a separate issue, I have a menu section (nav bar) showing three pages. When I select the lg size icon, it stays as a mobile nav bar. I have to drag the WYSIWYG Editor slightly further to the right to get the desktop menu bar to display (1039 width). I am working on Elements using a monitor with a resolution of 3440 x 1440 if that is relevant?
That’s a bug we need to fix. The correct size should always be shown.
Will look into that, it might be just the addition of the scrollbar - perhaps you have a mouse with a mechanical wheel?
Yes, I have a Logitech MX Master 3 mouse.
Yup, that’s the issue, we’ll get this fixed in the next couple of betas!
