Workspace panel improvements
@dan
  • Not sure how difficult this is but I have this layout : edit window on top and under it, the Component Editor and then to the right the Debug Log. Would it be possible for the debug panel to be the same height as the component panel?, ie allow the edit window to be wider (as the debug panel is currently taking up room up there)
  • Would love a search inside of the component editor so can find something in a hurry.
  • Would love the code to wrap inside of the component editor - I waste so much time scrolling sideways.
Thanks, Bill
Not currently. We did considered this, but had to draw implementing this, but had to draw the line somewhere. We felt 99% of users wouldn’t need/want this.
This is already available, just hit Command-F
It’s on the list to add as an option (some day)… However, you’re probably better off using external Dev Components then you can use the editor of your choice :blush:
OK - Command F - If I don’t see a button, it doesn’t exist :wink:
Devs want the other 2 things - pointing them to use tools elsewhere is not a good idea - make it easy on us so we can make a living.
Wow… you must have a hard time using computers!
And that’s why we have Element Dev Packs.
WRT Command-F, I have to use Shift-cmd-F
