Writer’s Mode
I was thinking about what would best serve me as a writer. Rather than fully functional WYSIWYG writing environment a Writer’s mode would be better. I’m not looking to override the theme. It would all be theme aware. This is not a design environment, just a clutter free editing and formatting environment.
Writer’s Mode – Feature Set
Core Text Editing
  • Plain text input with clean, distraction-free interface
  • Text formatting: bold, italic, underline, strikethrough
  • Paragraph styles:
    • Normal text
    • Block quote
    • Heading levels (H1–H3 for light structure)
    • Ordered list
    • Unordered list
    • Pre
    • Mono
  • Text alignment: left, center, right, justify
Links & References
  • Insert and edit hyperlinks (with optional title attribute)
  • Inline link preview (hover to show URL)
Writing Experience
  • Word and character count
  • Autosave and version history
  • Minimal toolbar that appears only on text selection or when hovering near the top
Layout & Appearance
  • Adjustable font size and line spacing
  • Choice of fonts (serif, sans-serif, monospace)
  • Ctrl+B for bold, Ctrl+K for link, etc.)
Images
  • Insert image
  • Inline or block display (choose whether it sits within text or on its own line)
  • Basic alignment: left, center, right
  • Adjustable width (percentage or preset sizes: small / medium / full width)
  • Add optional caption or alt text
  • Replace or remove image easily
  • Maintain aspect ratio automatically
A little more thinking. The way I see it activated is simply by gabbing everything inside an element; article, aside, etc.
What you’re describing is another entire app… have you looked at using a dedicated markdown app for this?
Here’s how I would see this working:
Build your site in Elements, then use a dedicated markdown editor (with all the features you need) to edit and upload the .md file to the server. The Elements CMS would pick-up this file and render it in on your site.
Not looking at the CMS. I like the feature but want a flat file system, less to go wrong. Instead why not make a .md option inside Elements?
Edit: it would need to honor the theme. Can you suggest one that does that? I know the CMS supports markdown already, I get it. But until it has a UI built into the app, not offline, it doesn’t matter to me regardless. 2¢
Just saw this thread. I guess that ain’t happening. :wink: I’m not doubting Elements is a designer’s app. However it leaves me behind. I design a site once and forget it. The real everyday use will be adding content. Elements has no good way for a webmaster, writer, or content creator to use it without a lot of “noise” getting in the way. As a result everything takes way longer and a lot more fidgeting to get work done and published.
https://forums.realmacsoftware.com/t/markdown-formatting/50523
