Any way to center and image in a container
Hello folks. I have an image in a container, and I would like to center it on the center of the page. I have set a max size of the image so it won’t go over 100% however when I open the page up wider than the image it moves from being from centered to the left. Can anyone please help? Thanks.
  1. Select the Image Component: Click on the image you want to center.
  2. Adjust Margin Settings: Use the Margin settings under the Spacing Control. Set the left and right margins to Auto to center the image horizontally.
  3. Ensure Container Size: Make sure the Container has a defined width or height if you’re centering vertically.
