Hey all!
I’m happy to announce a new site for RapidWeaver users that I have been working on.
Sign up at the bottom of the page to be notified when It fully launches.
Cheers!
Brandon
Hey all!
Cheers!
Brandon
Hey all!
I just finished adding the Product Tester Application to Beta Stacks
If you are interested in testing out upcoming products and/or services please fill out an application and you will be notified of opportunities as they arise.
Brandon Corlett
UPDATE: Just discovered that there when the checkbox field it set to “required” you must select every checkbox otherwise the form will not submit.
If you had any issues submitting your application and had not selected every product / service then this is likely the cause. Please refresh your page and resubmit your application.
I apologize for any inconvenience.
Sincerely,
Brandon
