I try to generate several banner-images for some individual subpages / There is an option in the configure area, but this CSS seemed to edit a general solution, but I like to have my own images in the head banners of the pages / What’s to do?
Almost impossible to answer without knowing what theme or a URL to look at.
Hi Scott, RW Blurry is my actual theme, where I try to edit the Banner image in this kind / Thank You in advance for helping me
Hi Mat,
You can find the info on the tutorials demo site here?
http://preview.weaverthemes.com/blurry/extras/tutorials/
ThanX, I’ve seen that tuto, but it only works in a general kind: one banner for all pages / I try to edit several banners to indiviualize these pages
Where are you pasting that code?
If you use that code and paste it on your individual Pages > Page Inspector you can indiviualize those pages by changing the name of the image to a different one.
Hi, vitor, thank You - that works / What is the recommeded size of a Blurry-Banner? My 1200 x 400 seemes too large ThanX in advance
The Blurry Theme adjusts the size of the images in the banner to cover all the space, to have a nice image as a cover in the banner you should be using those dimensions for visual quality, but it depends on what your needs are, if you use a 800x400 image the image will be resized up to cover all the space, just give it a try, and play what best suits your needs.
I’ll try it / Thank You
Blurry Theme: I try to edit H1 H2 H3 H4 in size and colour / Where can I manage this?
