Hey guys. I am trying for way too many hours and simply need some help. I have no ideas anymore how to fix it.
I am creating a website for my girlfriend.
The design she wants has for example
- picture left
- text right
But she wants the text allied with the bottom of the picture. So far it is not a problem. BUT when I for example alpine it for a 15in screen and switch to 27in which I am actually working on, the picture shoots through the roof and goes above the menu bar and totally out of order.
If I go smaller on the screen size the opposite happens. I get a big gap between menu bar and the content and the smaller size I go the bigger the gap. So yeah, I just need it to stay in the same relation to the other objects. Below this column (2 columns) I have 6 more with the same structure, so whatever fixes the problem with the first column, hopefully fixes it for the other ones as well (if I do the same). I WISH I COULD ATTACH PICTURES TO THIS POST.
I am using the BOTTOMSTICK Stack from DeFliGra.
Any ideas how I can prevent that from happening? I am sure for 95% it is not only simple but login what goes wrong.
THANKS A LOT FOR YOUR HELP.
Marcel
