When using the link in a custom component. The button in the single item. Is not responding. As you can see in the console it gets accessed in the Hook.
That’s a bug in Collections when used in a Custom Component.
If you’re using collections, I’d recommend doing it from a Dev Component, everything should work much better from there (including the link panel).
Let me know how you get on.
Yeah collections in devpacks was fine. Except of the other bug i posted.
Got it, just replied to that one ![]()
