I am using a collection and try to do somehting similiar like with the linklist.
In Safari Preview I get this:
In Elements it shows up:
When publishing it, its the same like in the Safari Preview
It might just be a coding error in your component somewhere (or it might be us
). Can you share the devpack with us and we can take a look?
You can email it to dan@realmacsoftware.com
done. Send it.
Looks like google does not want to send it. I try to zip it. In case you get more then one email now sorry ![]()
Hey @Beblebroks,
I’ve tested it here and it renders the HTML just fine in Safari ![]()
Can you try removing and re-adding the component to the page? I’m wondering if it got a little funky while you were developing it…
If you still get the issue can you send me the test project showing the issue?
Cheers!
Adding and readding still gives the same error. Maybe its the beta version that I am using and in the new one its fixed? I can try with the new beta and give you a feedback.
How strange, give it a try with the new beta tomorrow and if it still doesn’t work send over the project. We’ll get to the bottom of this ![]()
Hi @dan,
I might figured out the problem. As long as my collection is not part of a “Globals” component it works. In the screenshot I have 2 times each component. Above “Global” below just a component on the page.
Behaves differently.
Ah-ha! That sounds like a bug then, I’ll add it to the list!
Visible isn’t currently hooked up for collection items as it’s a fairly complex problem to solve. For now, you should be able to use “enable” instead.
@Beblebroks I have good news! In todays release (build v0.6.4) Collections now work in Globals ![]()
