Hi there - I’m trying to add some extra padding to the top and bottom of the ButtonMaker stack that I’ve just purchased. Any ideas of how to do this?
There’s an option inside the stack’s settings to increase the button height. Will that not do the trick?
Hi - I thought it might but that doesn’t allow for any spacing/padding within the button itself so the type of the button is still very close to the edges of the button top and bottom. I’d have thought there was something in there to adjust it so may just be missing it!
It works that way here unless I’m misunderstanding you.
Can I suggest you reduce the number of words so you have a single line button and see what that looks like? Buttons tend to be used for shortish instructions.
