Character encoding and social media in Depth theme
I am using @nickcates Depth theme. Whenever I publish a page with a £ (GB pound) symbol there seems to be a character encoding issue - the site is set to use UTF-8. See the screenshot to see what I mean. Is there a way around this?
Also it doesn’t seem that social icons have been added in the way other Nick Cates themes have. Is there a good looking social media stack anyone can recommend that would integrate well with Depth.
Thanks in advance.
Just now tried out the £ symbol in the new project file, using Depth stack and theme, and it worked well for me, see screenshot. If this still is an issue, can make me a single page project file, demonstating the issue, then send to support@nickcatesdesign.com. Thanks.
BTW, social icons will be added (in the same way as my other themes) in Depth 1.0.2.
Thanks for the reply @nickcates. It works well for me too (all previews, and previewing in Safari) until I publish live on the internet then the character issue is there. Can you try publishing the page you made and see if it works ok?
@nickcates I have sent you an email with a project file and link to the published version. Cheers :slight_smile:
