FedeMac
(Federico)
7 August 2017 09:13
1
Hi guys, I need some help with CODEX NavBar… I need to do an externel link…
Nav works perfect but I need to link to an external page for laguage selection.
Best
Freddie
How I could
klaatu
(klaatu)
7 August 2017 21:54
3
@FedeMac
Did you try a search in the forum?
One question which has come up a couple of times in the forums over the last year or two, and I don’t think was ever answered, concerns how to use external links in the amazing Codex theme by Michael David Design.
Codex is available here . I rate this theme as probably the best single page templates available for RapidWeaver and is well worth a look if a single long form page is what your project calls for.
Anyway, the issue in hand is how to use links to external pages in the Codex horizontal …
FedeMac
(Federico)
8 August 2017 06:18
4
THANK YOU… I will check it
FedeMac
(Federico)
8 August 2017 06:19
5
Great!!! I will try it, THANK YOU KLAATU
thang
(David)
8 August 2017 06:22
6
Sorry - I wasn’t aware that Codex is a single page theme. @klaatu 's quoting of @kryten 's post gives the directions on how to modify the theme to accommodate offsite links, so best to check that post.
FedeMac
(Federico)
8 August 2017 06:24
7
Thank you Thang… I will check klaatu
FedeMac
(Federico)
8 August 2017 07:12
9
FedeMac
(Federico)
8 August 2017 07:32
10
Everything OK… Consider this topic closed now, thanks for suggestions and advice.
