Container Element (Dropzone)
Hi everyone,
I am trying to get a pattern in the background (which works). But I am using a Container so I can spread over the entire width of my page.
But in the Element Editor it keeps showing the Dropzone which I won’t need in this case.
Is there a way to get rid of the Dropzone maybe with a switch?
Oh this is a good suggestion, and something I’ve found has got in the way when designing. I’ll get @ben to add a switch for it!
could you not use a Divider?
That has the background controls available, or are you using a specific feature on the Container?
How are you achieving that background pattern?
Hi @ben,
yes :man_facepalming:
with a Divider I can achieve that too. Awesome thanks. Only thing that I do not have in the Divider is the Border.
Then it’s probably better to add borders to the Divider - I’ll add it to the list! :slight_smile:
Sorry for Hijacking this divider thread:) Is it possibel to have text in the middle of the divider?
I do like the idea.
Hi @engrafiker and @pumpkin,
Here’s the thing…you can already create this inside of Elements. We’ve built the core components in such a way it allows for a lot of things to made.
In the example below I’m just using a flexbox… pretty cool, right?
:point_right: Open the Divider Project in Elements.
Hm, that sure is one way to do it :wink:
need to add more types of dividers
That’s a cool custom component, nice work :blush:
crash course svg’s, this hurts my head never used svg’s before, will get there, only adjusting one point at moment
Woah, that is really cool!
You could simplify it to a single divider, that way it’d be more flexible — and more usable in other places where you don’t want the text :thinking:
