Trying to streamline using drop zones
@dan trying to maker things easy for myself less code, maybe this is not possible using drop zone rather than have to produce hundreds of lines in properties ui
can see in safari but not in Elements
This looks impressive, but I’m not actually sure what you’re trying to do here, haha!
It’s this but I am streamlining so it’s just drag and drop grids boxes in rather than me write every screen size and individual grid boxes this way the grid boxes only show in safari not in Elements
Okay, I’m getting it now…
You’ve built a customizable grid/layout system that allows you to overlap Elements — That’s pretty wild. Wow :exploding_head:
Yes but if I use drop zones the grid box does not show in Elements only in Safari etc, if I write the entire grid it works but if I drop the line of code in the drop zone only shows in safari but the div on its own appears in Elements and Safari
I want to easily setup up every screen size and just create on component for each screen size to drop in a dropzone for multiple grid boxes it works except cannot see in Elements
Could there be a coding error? have you tired to run it through ChatGPT to check the code over?
I’ll try that but they are single lines of code for each bit
@dan I think this is something to do with how the dropzones work, when drop in a component it does not show in Elements but in does in safari. I just write the code in next to the dropzone and it works, can the dropzone be in a div, perhaps I am going in wrong direction
@dan ok, tried lots of thing, hand coding a grid inside my custom component works as previous video, but dropping my custom component in side my own custom component does not preview in Elements only shows in a browser,
Question should my custom component shown in Elements when in another of my custom components.
Question does a dropzone act as a div wrapper or is there limited what can be dropped in
ok I have broken this down to two lines of code, I would share project but see at end of video, I am in another country, not sure if this has something to do with that
Anyway you can see two lines of code nothing else and a dropzone, using two custom components one in another grid does not show only in safari or other browser, remove dropzone and drop code from inner into outer and grid appears, is this an expected outcome???
see at end of video I cannot see my previous projects, again I am in another country, unless there is an issue with Elements cloud
dropbox to project
also cannot download from Elements marketplace tried both templates whilst in another country
can download and upload everywhere else
Strange. What country/location is not working for you?
Caribbean, I uploaded the last video to cleanshot x and downloaded from cleanshot x no issues
Hi @upssjw,
Could you open the Elements preferences and check that you’re still signed into your account? If you are, try signing out and back in again.
Cheers
@tpbradley signed out and signed in, video below, uploaded to cleanshot and I downloaded from cleanshot website
Thanks Steve,
Could you choose Help → Copy Support Logs, save the log file and send it to me. You can send me a private message if you like. Cheers
how do I send a private message
You should be able to click on my name, then choose “Message”
doesn’t let me add a txt file
I think it’ll accept a zip file, right click it and choose Compress
