Customize links in built in menu - add parameters / query string
I need to pass parameters through a top level menu button (using the built in menu)
Example URL?parameter=[@field]
I you were using my Foundation theme and stacks, most of the menu stacks that ship with it have a custom HTML feature that would allow you to customize the link that each menu item goes to.
Thanks Joe, believe me, I’d rather be using your Foundation stacks (I usually do), but this is for a custom internal site for a customer w/ out-dated browsers (like OLD IE)
Eek. Good Luck with that…
What exactly can’t you do? I, using megamenu, make the URL into: blahblah.php?keyword=whatever
I then use Bryn Owens PostSwitch stack to pick up that variable to display whatever content I need (or in my case pick up stuff from a database of products)
