Dev Diary Ep64 - More Updates!
Hello again!
This is the final video of the week — Phew!
In this one we dive into the changes we’ve made to Accordions and Tags based on your feedback! :smiley:
We also get a little geeky and dive into Component Collections. If you’re building a custom components you’re going to want to watch this one.
Useful Links
Suggest a Feature
Don’t forget you can vote and suggest the features you want on our open Roadmap page.
Get the Beta
If you’d like an invite to the private beta, just post a reply in this thread, and we’ll email you an invite with all the details! :grinning:
Thanks for Your Feedback
Thank you!
See you soon,
Dan & Team Realmac.
Wow! :exploding_head: The addition of Collections is one of the most valuable enhancements so far for building custom and dev components. A simple solution for something that is crucial in many components. Absolutely fantastic work by the RW team. Elements is quickly becoming a mature product in this way.
Absolutely, thanks for your support @Bartje :blush:
Okay, five videos. Let’s see if you can top yourself next week ;~).
top himself…bad choice of phrases hahahaha
@Dan, I downloaded the tables project on GitHub, but I can’t open your Elements file. I’m on the latest b36.
Oh, maybe it got corrupt… Try this Elements Cloud link :blush:
elementsapp://downloadDocument/lV5W8ou36gFm
You’ll obvisouly need to have the table dev pack added to Elements for it to load.
Thanks! This one opens.
I cannot get the properties from the collections properties.json file to appear in the main properties.json. How does the latter retrieve the correct data? The identifier key to the collection is set correctly. Are there other keys that I need or need to set in a specific way? The structure is identical to the Tables example from the video and the files on Github.
See this just posted: Collections: main properties requirement
@Bartje, @logrunner glad you got it sorted, and yes we’ll update the docs to note that you need to register your collection in the properties.json file :sweat_smile:
This is really cool. Will it be possible to alt-drag a row to add a copy?
Still got some questions:
  1. What’s the use of the property key?
  2. How does the main template.html file gets access to the properties of the properties.json file in the collections folder? They do appear in the inspector pane, but do not show up in the edit or preview mode.
You can alt-drag component to duplicate them, but not records from a collection yet — when we have a better UI for managing records you’ll be able to do this!
So excited to download the Beta for Elements. Thank you for all the incredible work you guys are doing!
@blackbird You can now purchase a copy here :wink:
@dan What is Form Webhooks that is only available in Elements Pro?
Or, should I wait for the next video for the answer? :wink:
Oh that is some really good stuff I can’t talk about yet :laughing:
It won’t be in today’s video, but hopefully later in the week or next. Stay tuned.
Great updates, Dan. So many of the functions I have needed (usually via Stacks) are starting to make their way to Elements as components. Super encouraging/exciting.
I just upvoted ‘Tabs’ on the Roadmap; seems like it could be a variant of this component? (Maybe I am simplifying.) Tabs are still an elegant solution to displaying lots of information in an economical (space-wise) fashion.
