Hello again,
This latest build fixes a whole host of bugs and adds some nice quality-of-life improvements. There are a few very minor issues to be aware of, please read the known issues list below before giving feedback.
Known Issue:
- If you have a mobile logo on the Menu Component, you might need to add margin to the bottom of that logo, as the mobile nav items no longer have any margin applied.
- The new keyboard navigation doesn’t work on scrollable pages due to the browser intercepting arrow presses. We’re currently working on a fix for this.
What’s New in buiuld 0.8.0?
- Fixed layering issue with the Background Component.
- Make sure Reveal Component responsive options are correctly set.
- Fixed mobile menu close spacing when no logo is visible.
- Favicons now use relative paths.
- Select node when dragging in new Components.
- Resources now keep the correct folder structure on export.
- JavaScript for custom components is now exported.
- Duplicate now works for Globals.
- Fixed issue with missing font resources.
- Added keyboard support for navigating in the editor/node browser.
Purchase a License
Download and Update
Give Feedback
