Elements 1.0.9 (23745 )
Hello again,
This latest build continues our work on improving publishing, along with a range of fixes across various components. If you like building custom components, you’ll love the new syntax validation in the Properties editor/
Along with fixes, the Form component now supports reCAPTCHA, Turnstile, hCaptcha, and a classic style honeypot. More flexibility, better spam protection, and easier setup!
What’s New in Elements 1.0.9?
  • :fire: Added syntax validation to the Custom Component properties editor
  • Added classic Honeypot spam trap to Forms
  • Anchor links now work correctly in the Background component
  • Fixed various issues with the Form component
  • Fixed a bug where the Menu component output empty links
  • Tentative fix for making Transform settings responsive
  • Fixed an issue where large backup files could fail to transfer during publishing
  • Fixed an issue where asset files from Dev Packs weren’t published
  • Switching pages no longer marks them as changed
  • Sitemap has correct last published date
  • Page info shows the correct URL
Try the Demo
The new trial mode in Elements lets you explore the full app and build up to three pages, giving you a feel for the design workflow and features. While export and publishing are disabled in the trial, everything else is fully functional, so you can see exactly how Elements works before committing.
It’s the best way to experience the speed and simplicity of modern website building with Elements. You can now Download Elements with the new trial mode.
Purchase a License
Get the Update
Give Feedback
The publishing speed seems to have speeded up by a significant margin - in particular the exporting part. It is now very quick. :+1:
Not before.
Ah… we now validate the site URL field and remove slashes on the end of the domain name. Go into site settings and make sure there is no slash on the end of the domain name.
And yes, we’ll get the help text changed below the field to reflect this :wink:
Really happy with the updates to the form component. Although I have noticed that when using Turnstile it does not matter if you choose “visible” or “invisible” it always seems to be present.
My only request would be if there was some way to CENTER the display of the Turnstile confirmation display.
Also really happy to see that there is no Turnstile and reCaptcha token code in the resulting email, now very clean.
@dan I also have noticed that the upload speed seems to have increased for all but ONE of my sites. This one site is painfully slow uploading, takes about 4 times as long as the others, even though it is going to the same servers as the others.
It has been doing this for some time now. I even rebuilt it from scratch, thinking that there might have been some crud left over from the early days when I first started the project. But it makes no difference.
I wonder what the problem might be?
