Hello again,
Following up on Beta 33 from Tuesday, Beta 34 brings a mix of bug fixes and developer-focused improvements! ![]()
This update introduces a new plain link option in the link panel, paving the way for PHP support in upcoming components. Plus, PHP files in Dev Components now render HTML directly in the Editor!
What’s New in Elements Beta 34 (Build 23213)?
- Added a plain link option in the link panel to support PHP in upcoming components
- PHP Files in Dev Components will now render HTML in the Editor (PHP will only render in Preview).
- Container: Reverted link change to fix hover issues (HTML does not support nested href tags)
- Fixed Dark/Light Mode issues
- No longer outputs double slashes in path when site is previewed
- Link attributes are now saved
- Open in new window link setting is now saved
- Fixed missing toolbar icons on older versions of macOS
- Fixed Workspace crashes on macOS 10.13 and 10.14
Known Issues
We’re aware of some issues effecting text styling, these will be fixed in a future build once we’ve upgraded to Tailwind V4.
Join the Private Beta
Post a comment below requesting access and we’ll send you the details via the email address attached to your forum account.
Get the Update
Give Feedback
Request a Feature
You can help make Elements even better by sharing your suggestions and voting on others.
Please remember to search before posting as it may have already been suggested. If your idea is already listed, you might want to upvote it. The more votes an idea gets the sooner it’ll get implemented.
