Elements Beta 33 (Build 23199)
Hello,
We’ve been working hard this past week optimizing and adding some nice touches to the new Workspace feature. The UI in this new beta is faster and allows you to scale the editor…
Watch Dev Diary 58 to see the new Scalable Editor in action!
What’s New in Elements Beta 33 (23199)?
  • New Scalable Editor Added
  • Optimized UI for a smoother and faster experience
  • Added keyboard shortcuts for responsive screen sizes (cmd-1, cmd-2, etc…)
  • Editor will now stick to edges on largest screen size when resizing
  • Opening or starting new projects no longer defaults to the mobile screen size
  • Fixed a Beachball issue when switching Workspaces
  • Fixed layout issues with screens and dark/light mode toggle
  • Custom Classes are now supported in the Menu Component
  • Fixed sizing issue in Image Component.
Known Issues
We’re aware of some issues effecting text styling, these will be fixed in a future build once we’ve upgraded to Tailwind V4.
Join the Private Beta
Post a comment below requesting access and we’ll send you the details via the email address attached to your forum account.
Get the Update
Give Feedback
Request a Feature
You can help make Elements even better by sharing your suggestions and voting on others.
Please remember to search before posting as it may have already been suggested. If your idea is already listed, you might want to upvote it. The more votes an idea gets the sooner it’ll get implemented.
Something wrong with Dark Mode in the latest version?
Ah sorry, that bug seems to have sneaked in as we were working on the new editor — We’ll push out another beta tomorrow (Wednesday) to get that fixed!
Has something happened to Hover as well?
Oh that does look like another issue, sorry. Can you send over that project file again so we can take a look?
When I try to update to the latest beta I see this error.
Hi @mrTablet - I can’t replicate the hover issue shown in your video. Do you think you could send us a project with the issue in?
Thanks :slight_smile:
Hi @ben I have sent you a message…
We got it, thanks! Just looking into the issue now and will report back shortly!
This one is fixed and will be included in the next beta :slight_smile:
