Elements Beta 4 (Beta 22835)
Thanks for all the feedback so far. Just like the last beta, every single fix in this build is a direct result of the feedback you’ve posted on the forum, so thank you and keep it coming.
If the bug you reported is not fixed in this build don’t worry, it’s ticketed and we’ll bet getting round to it shortly.
What’s Fixed in Build 22833 22835
  • Duplicating pages now works
  • Folder Browser preview issue now fixed
  • Projects with Folders can now be saved
  • Resource path for images is now set correctly when previewing and exporting
  • Code editor no longer crashes with entering foreign characters
  • Added new page inspector
  • Added new media inspector
  • Added description filed for page
  • Added new Media Object Component
  • Added new Card Component
  • Heading: Added alignment container options
  • Paragraph: Added alignment container options
  • Fixed issue with using sand and mono fonts in themes.
  • Image: Added alignment container options
  • Image: Correctly generate image sizes
  • Image: Added Lightbox support
  • Flex: Added more sizing options
  • Section: Added container sizing
  • Flex: Added container sizing
  • Grid: Added container sizing
  • Menu: Added more options for sizing logo
Start Your Update Engines
Elements should prompt you while it’s running to let you know there’s an update, if it doesn’t you can select the “Check for Updates…” menu option from the “Elements” app menu. You can also download the app again from the confirmation email you received as that link will ALWAYS give you the latest version.
Give us your Feedback
All feedback should be posted in the Beta Feedback category so we can keep track of it in one place.
Get the Beta
If you’ve already signed-up it might be a while before you get an email as we’re working our way through all the initial feedback. Hang tight for a little longer, you will get early access in the coming weeks.
If you’r not on the list, you should sign-up up here be notified when the beta is publicly available.
Thanks again for all the support!
Dan & Team Realmac
No update notice or recognition of an update in Elements yet.
Same here.
Launched Elements and it gave me the update notification and I installed the update OK.
Nope. Maybe it is a country thing?
We’re looking into this now, in the meantime you can download the app again from the confirmation email you received as that link will ALWAYS give you the latest version.
Dan
Blocs user here. I’d really like to try the Elements Beta.
Regards
M@
Using the email download link worked. Thanks.
No problem, you’re on the list. Expect an email in the coming days/weeks as we roll the beta out to more users.
Just out of interest, how did you hear about Elements?
Important Update: We’ve just pushed out a beta update (that fixes themishing heading text), please check for updates or download the app again from the confirmation email you received as that link will ALWAYS give you the latest version (22835)
Update check worked and new version installed. :slightly_smiling_face:
Really liking both the media object and card components. These will make it so much faster to do common grid style layouts.
The new inspector would be the perfect place to put component descriptions and Global previews as mentioned in another thread :slight_smile:
The update has broken a few of the tests I’ve been doing - I’m guessing due to the new sizing and alignment addirions. Even the RealMac supplied test LinkedIn project opened looking completely different to how it did in the previous beta.
Appreciate the continued improvements, many thanks.
Yes, in the testing I;'ve done it’s made it really fast to put together layouts :smiling_face_with_three_hearts:
Yes, it sure would!
Ah yes sorry about that, all of the layout components (grid, flex, and section) have had the layout settings changed. Unfortunately this is just part of the beta process as we improve and fix things. As the beta progresses things will get more stable!
Appreciate all the feedback too :smiling_face:
