It would be useful to have a comment feature added to the Elements Language, for example:
@@ This is a comment about the code below!
@if(switch)
<div>This is a Div</div>
@endif
I am not clear whether you can add comments to @if, @endif etc ? ![]()
@if(switch)
@endif
Maybe I’m missing something… but why not just use HTML comments?
<!-- This is an HTML comment about the code below! -->
@if(switch)
@endif
@dan ,
Yes you can but then it gets output with the HTML. I was looking not to have the comment published to the website. I could hid a comment with PHP but seems somewhat counter-intuitive?
You could use an if statement for now. It’s not as elegant as a comment but it’ll work.
@if(comment) This is an HTML comment about the code below! @endif
@if(switch)
@endif
Because the comment property doesn’t exist, it’ll evaluate to false and never output the comment text.
you could also check if you’re in edit mode:
@if(edit)
<!-- This is my comment for edit mode only -->
@endif
