I’m wondering what happens when you have a default value set for a control and you set the following:
Will a value be used when enabled is false?
Will a value be used when visible is false?
Thanks,
Bill
Stack-Its
Thanks,
Bill
Stack-Its
The enabled and visible settings on properties only apply to the UI controls within the inspector. The value of the property is always accessible from the template.
Note: Visible should work for all controls, enabled isn’t fully implemented yet - so some control will stay active when expression is false.
