How I place my data in RW 6?
Favicon is a setting in General Configurations.
Gracias Mark
Just want to know how to write the text as “YoSoyLajas.Org.”
I can only assume that they text is converted into a graphic, which becomes the favicon.
You would need to have an Extended Validation SSL Certificate to take advantage of that. The EV SSL activates both the padlock and the green address bar in all major browsers. They also run well over $500 a year. More information here.
Thanks for answering me again.
I try that, at no avail.
Gracias Dave. After read your info, I decide it was too much for me. This is the end of my quest.
Humberto,
It’s certainly expensive, isn’t it. You could just out a regular, small, graphic favicon. Good luck!
