Thanks for your time.
I´ve jus installed SSL certificate and I´ve found favicon is the only one insecure item in my web page according with https://www.whynopadlock.com where I´m checking.
Maybe changing the link path from absolute to relative could solved the problem but I don’t know how to do it.
Any other way to fix it?
Thanks in advance.
Pablo
Did you change the base url of your site in the rw project general settings from http, to https ? Then republish all files?
thanks you, it´s worked.
Solved.¡!!!
