Filtering on front matter fields
I hope @ben notices this post. :slight_smile:
When can we expect to be able to filter on front matter fields in the collection component? That would make the CMS much more flexible. Today, we have to use tags, and it’s more like a blog-way to do things. I don’t want to make blogs, but solutions for different kind of websites.
I hope this will be happening… :slight_smile:
Can you give us some more information on what kinds of things you want to filter by?
Some example of how you’d use this would be super helpful, the more details the better :slightly_smiling_face:
I want to be able to filter on any custom front-matter field, so it can be customized and flexible. It’s okey if we have to type the name of the field, for instance: category, sold, active, inactive, on-stock… Kind of when you make a database solution - you want things kind of in a system, you need to filter down to the records you want to show.
This, because, often the tags can be used for something else (tagging).
For instance, if there’s a little listing for an auction or something, I would like to filter on my front matter field called sold to shift the objects that are sold to a separate view of the sold items.
