Hi everyone.
Hi Joe!
I want to use the drilldown menu but it doesn’t show up only when I select the drilldown menu.
I want to set it up in the template lightbox, but I can’t do anything about it. And if I set up the drilldown in the menu by itself, without using the template, it does show up.
The other dropdowns and accordions show up, but only this drilldown doesn’t show up.
I’ve attached a picture.
This is when the accordion is selected.
This is when the drill down selection is made.
Do I need to make any other special settings to use the drilldown menus?
Why can’t I just see the drill down menu?
Thank you for your guidance.
Translated with DeepL Translate: The world's most accurate translator (free version)
