Menu in a lightbox
New to Foundation 6 and building own template.
I have a menu that works fine, but when put into a lightbox opened by the hamburger for small the links inside the light box menu don’t work.
It’s a single page website , at the moment, so the links are to containers. Suggestions most welcome
Dan
Problem resolved.
Dan,
Just in case someone else searchesa and asks the same question, can you post the outcome.
Kevin
The problem was resolved by deleting stacks which contained the menu until it worked. Standard fault finding by elimination.
Even better solution use Off Canvas to contain the menu.
There is a lightbox menu template in the F6 templates as well.
